AHar_94XLT
- July 23, 2006
- Fishkill
- 94 sport
I should start with a little history: Two months ago I was getting "cold" delayed reverse and occasional slipping above 40 mph in normal temp range. A mechanic said it was likely the direct clutch - but did not push doing the work. I found fluid in the line so replaced the vacuum modulator and flushed/changed the filter and fluid. Added TransX. The delayed reverse and slipping went away due to the transx.
Next and the current problem, this week - I lost shifting into 3rd when not fully warmed up. Reverse delay seems to be comming back (again only when cold).
I rechecked the VM line for fluid -none present, and checked the intake manifolds they do not leak cold.
Anyone have ideas on a cause of failure ?
Thanks in advance,
Thanks in advance,
