philwr
- October 7, 2002
- Fort Wayne, IN
- 94 Explorer EB Edition
I printed out the entire rebuild diary I found on here to replace my output shaft. Everything working out good. BUT....the um drive after you install the center support.....OD????...but whatever the last band you would install on the installation the pin that hold the little A clip in, is there a hole in the center support that it slide into?? Or does it just kind of rest on the center support? The way the picture looked after you install the center support with the big snap ring, in the picture the gap in the snap ring was located twards the bolt that goes through the VB so it doesnt look like there would be a slot in the center support, sorry if this doesnt make sense but just double checking
by the way, after everything is put back together is there any way to kind of check to make sure its all situated, but turing the torque convertor or something like that, just to make sure it works
thanks again everyone, even if i have to tear it back down a little still saves me about a grand that would go to the tranny shop
