vulture007
- May 28, 2005
- Seattle, WA
- 92 XLT
I have a 92 explorer XLT with 128k miles. Well looked after, tranny fluid changed 18 mos ago.
A while back the tranny lost 2nd gear. I cannot get to it at all, even by selecting 2nd. I am able to shift fom 1st to 3rd by getting up to 25mph and backing off the gas for 2 secs and then gently picking up from there once in third.
I checked a bunch of stuff without any luck. Vacuum is fine, checked the modulator (no fluid in the lines and holds vacuum), checked the intermediate band - the adjustment bolt tightens up fine which makes me think that the band is intact. I wanted to get some advice on what to look into next since all of these require a fair bit of work (like dropping the transfer case or removing the cat). Anyhow, this what I was thinking of checking next in order:
1. The servo
2. The governor
3. Drop the valve body and look in there.
Any advice will be greatly appreciated.
Thanks
V
1. The servo
2. The governor
Thanks
V
