A4LD transmission help | Ford Explorer Forums
mt.vernon ohio
93 XLT
it drives fine in over drive,drive,2nd and 1st and will take off in nutral up to about 25 mph then slips in to nutral the problem in i have no reverse it acts like its in park or something and won't even rev the engine. any help would be nice
Sounds more to me link you have a linkage issue. Has the linkage suffered any damage? It just doesn't sound like the manual valve is in the proper position when you select the different gear settings.
we found the problem it was the rev cluch was burnt out and the forwarn was welded together thanks for the help
