saxon
- March 30, 2006
- seattle, wa
- '91 & '93 EB, 4WD, 4-door
Called my machine shop and asked about checking the VB for flatness. Manager (someone I know pretty well) said that VB was probably not flat but as he did not know what the VB's tolerances of warpage are that I should call a local transmission shop and ask. My knowledge of local trans. shop tells me that no-one knows anything about transmissions and that they are all 'transmission replacement technicians." I can't think of anyone to call who would have a clue on this. Cynic, yeah, I know. Don't need flaming on this; I won't let anyone with a wrench within 15' of my GP bikes or my bmw (car).
At any rate, he also said that he would not surface the VB because it would then be too short. He suggested checking it against a thick piece of glass and if it seemed warped, sanding it against some wet (I use WD-40 for this) 2000 grit sandpaper on the glass. I recently did this process to flatten the bottom surface of a Weber 32/36 DGEV carburetor with good success (to fix an air leak).
If warpage is present and correction is warranted, I would only do the sanding after bagging all of the valves and springs from the bores, then afterwards, clean the VB to near surgical standards.
