koda2000
- September 2, 2011
- x
so i just repaired the driver's side front window in my daughter's 2000 Mountaineer (the glass had pulled out of the regulator and the channel/track). it's been working great for almost a week now, so i decided to re-install the weather barrier and interior door panel. i get all done, put away my tools and decide to test it one more time and at first only the other 3 windows work and then it blows the 30A fuse in the power dist box.
so i figure i must have shorted a wire somehow. pull it apart again and unwrap the wiring harness, but everything looks good. tried unplugging the window motor and hitting the down button and the fuse still blows. wiggle all the wires around and the fuse doesn't blow at first, but blows soon after.
in looking at the wiring diagram, i believe the problem is with the red wire that comes from the dash, through the door and connects directly to the motor. this wire comes from the AUTO DOWN relay, GEM and ACC delay relay (very complicated diagram).
so now i'm thinking that there's a short in the door wiring cylinder thingy. why it has picked now to act up i don't know, i never touched this wire during my repairs (coincidence... ?). it's too cold and wet to mess with today, but any opinions are welcome. i think i'll probably end up having to remove the door to work in there and i'm not looking forward to it.
