ABS diagnostic connector. | Ford Explorer Forums
baphomet666
Bordeaux,FRANCE
Explorer.1994. 4WD
hello all,
:crazy: the question will surprise you I am sure of that.
but can you explain what is the exact role of the compressor on my truck.
Thank you very much
:exp:
Dominik- are you asking about the Air Conditioning compressor?
If u r talking bout the a.I.r. Pump it pumps fresh air into your exhaus to help make the cats more efficiant.
:rolleyes: sometimes I feel terribly stupid. when I ask questions. Thank you MisterJoe Dirt;)
Obviously the compressor manages Air Conditioning
for continue behind the radiator bloc fluid there is a RED taken "anti-lock test "the translator does not give me a good explanation, you could tell me what use this jack
Really my apologies to those questions, but I do not know , and that is how I prefer to ask for explanations
:dunno:
:exp:
;) c'est déja pas facile pour moi même avec le traducteur alors si vous me parler en code c'est encore pire
:exp:
Are you referring to the ABS pump or a solenoid block?
This
:exp:
That's the ABS test connector. This is where you connect an ABS scan tool to retrieve codes. ABS stands for anti lock braking system. Your thread was renamed, and moved into the International Explorers section.
:thumbsup:Thank you very much mister BrooklynBay
:exp:
