1991 4.0-Accessing EEC-IV Diagnostic Connector | Ford Explorer - Ford Ranger Forums - Serious Explorations
Foopherenz
Patchogue, NY
1991 2-Door
OK I'm being dumb. I'm normally pretty good with vehicles, but my brain isn't working.
I have a 91 Explorer with a 4.0 (recently purchased). My wife drove it today (Mistake). She said it stalled twice and the check engine light came on and went off several times.
I want to access the EEC-IV diagnostic connector to try an retrieve the codes, but I can't get the damn cover off. What am I screwing up?
RiverRat
San Diego, Ca
1996 V8 Ranger 4x4
There is a little plastic tab that keeps the connector in the cover. It should "wiggle" out. If not help it by using a flat screwdriver to open up the tab.
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
Sometimes the cover doesn't come off easily. The cover on my comp. diagnostic never does.
I think if we had 2nd gens our diagnostic connector would be in the cab! So much nicer...
Foopherenz
Patchogue, NY
1991 2-Door
OK, I just brake the little plastic clip and yank the cover off. That worked well.
I pulled a code 66 (Mass Air Flow sensor circuit out0of-range). I cleared the code and will see if it comes back.
Thanks for the help.
dejello
perpetually unconcious
College Station, TX
Also, it could just be that the connector for the MAS just came loose... Much much cheaper if it's that
SVO
Moderator Emeritus/Doctor
Moderator Emeritus
Bastrop/Austin, Tx
Turbocharged Navajo LX
I have my old one if you need it, I'll let it go cheap since I have my Pro Flow meter in it's place.
$45???????
