mrmayhem
- May 25, 2003
- sunrise florida
- 1999 XLS
The ABS light in my 99 XLS recently used to come on from a cold start, but after several minutes (and a restart of the engine), the light would go off. Now its on all the time... no matter what i try. I looked at the rear sensor on the axle, attempted to get a ohm reading but didn't get any reading at all. I removed the sensor.. cleaned it a bit and re-seated it. I also removed and cleaned the front wheel sensors. Using the chiltons manual.. i also checked the main abs module with the ohm-meter but the meter went crazy... so i am pretty sure the meter may be out of wack. (or i'm doing something wrong). I disconnected the battery for about a half hour hoping to 'reset' it... but nothing has worked so far. Has anyone had this problem.. and if so.. what else can i check... i'd rather not go to the dealer or brake shop if i can do it myself.
