marine7294
- May 24, 2014
- Brenham, Texas
- 1999 Ford Explorer
I have a 1999 Ford Explorer Eddie Bauer edition. The Abs light stays on all the time. Codes 1230 and 1102. A shop has replaced both front speed sensors and the rear sensors. Also replaced the ABS module. I check continuity between the rear abs connector and the connector on the rail. All checks good. All fuses have been checked and all is good. What else can be the problem? Also, the cruise does not engage. If while holding down the off button I turn on the ignition switch, the speed control light flashes on the off once. Nothing happens with the on button.
