check the resistance on all sensors to make sure they are to spec. Also check the connectors on them and the speed sensors (could just be moisture).
Does your code reader read the abs unit as a lot of them don't!!
You'll need to get someone with fancy diagnostics to read the DTCs for you. They will need to be able to read US vehicle systems. I'll PM you the relevant pages of the workshop manual for you to check through the system as Jan says. Say hi to my home town for me! GRoB.
