ABS Problem...HELP | Ford Explorer Forums
ABS Problem...HELP
Badmotorskooter
ann arbor, MI
1998 sport
I have a 1998 Sport 4x4 4.0, I put new pads and rotors on the front and now when I hit the brakes the abs buzzes just before I stop. its like coming ot a stop on a dusting of snow, the abs activates just as i come ot a stop. any ideas? any help would realld be apreciated.
Many have come across your same issue. I believe it is a sensor issue. See if theres any trash in the way of the abs sensors (on the front wheels) and excitor ring to see if the signal is getting interupted. Also, did you push your fluid back into your master cylinder or did you let the old fluid out?
-Drew
I Pushed the fluid back, a no no I know, But I forgot at the the time.....;-(
try bleeding your system and see if that fixes the problem
-Drew
