ABS Problems-need an expert... | Ford Explorer Forums
DownAnother1
charlotte, nc
96 unknown
hey guys, just did an axle swap on a toyota tacoma and used a 96 exp limited slip (D4) axle with disk breaks.
now the toyota ABS system uses a series of pulses 49 per second from each wheel and sends it bak to the computer.
my question to you is: what sort of system does ford use so that i might better understand how to mesh these two systems.
how does the sensor relay information back to the computer? and what is the rate?
my current ABS in the 04 tacoma is recognizing the sensor but after a few minutes is ignoring the signal... out of range possibly????
help!! :(
