rschwartz
- September 10, 2009
- York, Pa
- 1995 Explorer XLT
I have a 1995 explorer and had the abs light checked and was told the driver side needs to be replaced. Someone told me that when you replace one you need to do the other because they are calibrated together.
While looking for a cheaper part I found that the driver sensor is more expensive than the passenger side. I don't believe that both need replaced.
However, I would like to know if this is true and how to replace the driver side, as well as where to fine one at a reasonable cost.
Thank you.
Randy
Thank you.
Randy
