ABS + squeel noise when braking | Ford Explorer Forums
aruek
Panamá, Latin America
Sport Trac 2004 XLT
Guys, I hope you can put some light with this problem that is driving me crazy.
Squeel noise when braking in the area where the booster is. (It sounds like when you rub a rubber bike pneumatic with itself)
It only happens when braking.
Master cylinder was leaking so it got replaced but it did not fixed the noise.
ABS control module was replaced also with no good results.
If I hit the brakes hard the car tries to go to the right slightly.
INTERESTING... when the dash ABS turns ON the problems goes away and the car brakes normal, obviously without ABS capability. As soon as the abs light goes OFF the sound reveals again.
Any help, tips or something that can solve this issue?
I will reall appreciate it. Thanks!
