Do you have the manual or automatic climate control? In theory you could build or rework one of those modules to supply the fan with higher voltage, using the existing fan.
It would run hotter and wear out faster but that's the catch with any higher RPM fan in the same space available for it.
Anyway the blower motor resistor pack was marginal already, prone to fail within the life of the vehicle and so is the automatic climate control transistor pack, so you'd probably need a control box mounted somewhere else with its own fan to cool it. THIS WOULD BE THE CASE WITH ANY FAN USING HIGHER CURRENT. The higher airflow rate "might" cool those better, but I'm guessing that there will be a larger control module heat increase than airflow increase because the rest of the system (air passages) remains the same.
The other route is you just source a higher RPM motor with the same shaft diameter, and it need not be remotely related to explorers or automotive use at all, just a DC fan with a bit higher RPM that's not so long that it doesn't fit in the available space and with tapped holes to mount it, then you cut the old one off the bracket and bolt the new one on, cannibalizing the connector to put on the new fan or buy a new connector if you can source it, or find any random mating pair of connectors at an electronics supply house and put the male end on the OEM wiring to replace the OEM connector.
Frankly I don't think it will help much in summer since higher airflow would be warmer, but in winter the heater is a smaller % of total engine heat so you'd see more difference then, but S. Carolina doesn't get cold enough to need it.
