newts96xplr
- February 8, 2006
- Thousand Oaks, CA
- 2007 Ironman Edition V6
Okay,
Here is the problem. I have a 96 X with manual controls and my ac fan works intermittenly (whenever the hell it wants). I have read many posts here about similar issues related to the resistor, relay & blower motor.
I have systematically replaced the following ONE BY ONE and tested the system each time for several days to see if the problem was fixed.
1. Replaced all 3 control knobs (fan speed, temp & ac knob). NOT FIXED
2. Replaced the blower motor resistor. NOT FIXED
3. Replaced the relay. NOT FIXED.
4. Blend door checked and works fine.
The weird thing is that my rear AC controls work PERFECT all the time, the AC blows and blows cold air no problem (and hot air if I want.
The front however, DOES blow cold AC air when the ac control knob is on "AC" mode, so it is blowing air from the outside (the air is ice cold), but I have no control in the fan speed. When the control know is turned to "MAX AC" i get NOTHING, even if the fan speed know is on the high speed. When I have it on vent and I adjust the temp know I can get either cool or hot vent air.
Please help. My dealer wants minimum $250 to look at it. I can do most of the work myself, but I do not know where else to go from here, because sometimes the fan comes on while driving and all works fine, no problem. I don't think that it is the blower motor as when it works it works fine.
Thanks,
Thanks,
