Ac issue-not recirc or blend door | Ford Explorer Forums
Caleb33
Orlando
2002 ford explorer
I put this question here after a few hours of searching and working on the truck. My ac won't turn on (ac button won't light up) when on normal ac. The air will
Ow but not cold and the compressor is off. The only way to get it on is to put it on max ac. I also have full control over hot, just no ac while it is not on max ac.
Ill list the things I've tried after looking at all the other suggestion threads and see what you guys think.
Recirc door and actuator-fixed about a month ago
Blend motor and door-fine
Compressor and all vac lines- fine
Havac lines- fine
Can't think what else it is maybe you guys know.
Could it be your control switch itself? Maybe contacts are bad when you place in normal AC.
