AC not working. AC "spins" for a second then clicks off then repeats. | Page 2 | Ford Explorer Forums
Guys don't forget that if you need to add refrigerant then you have a problem that you really need to get fixed. You don't "use up" refrigerant no matter have much you use your A/C and it never goes bad (well at least not in your life time)
You are 100% correct. Although, up here in the frozen north where people generally only use their A/C about 3 months out of the year, or less, the O-rings just dry up from no oil on them. Charge the system up again, and sniff for leaks with one of those little electronic sniffer gizmos, and no leaks are found. The shop I work at doesn't do A/C (due to the aforementioned licensing) but we send them out another local shop that services them. They add UV dye to the system too, and there have been many that just leaked out because they weren't being used and the O-rings shrunk up just enough to cause a slow leak.
When I was in Arizona, we saw about a tenth the amount of A/C problems as here. Mostly because they were being used a lot more, and the systems stayed nice and lubricated.
up here in the north....we use our front defrost everyday, having said that when the defrost is engaged so is the a/c compressor so it shouldn't dry o-rings because it is not idle......
The systems do have a thermo-switch on them so the compressor doesn't freeze up. On my Explorer it's 30°F. My Chrysler and GM products seemed to be right around 38°F. Any temperature lower than that, and the A/C won't engage whether the defroster is used or not.
