trozei123
- March 1, 2015
- 1992 Explorer XLT 4x4
ok, this has officially stumped me and I could use the experts on here for verification. here's the story.
my 92 explorer has not had working ac very long. everytime I have tried to fix it, it always seems to fail. the only parts that have been replaced are the ac compressor cycling switch (i assume that's what its called that is attached to the accumulator) and the orifice tube. everything else is original as far as I know. I have enough r134a in the system to make the compressor kick on, and cycle off. I don't want to add too much refrigerant, so I only have about 18-20 oz in the system.
now for my quandary...
my ac pressures are not seeming to make sense. when I first hook up the gauge set and get a reading with the engine off, the low side reads about 55 psi and the high side reads about 90. this is with the engine cold and the ambient temp outside of 78 degrees. when I turn the ac on, the compressor kicks on and the low side comes down to 20 psi. once that happens, the compressor will shut off as the pressure goes back up to 40. after that, the compressor will come back on, and repeat the same procedure. while all this is going on, the high side comes up to about 125 psi with the compressor on. when it shuts off, the high side drops down to about 75 or so. then the compressor will come back on, and the same procedure happens. my vent temps are showing 41 degrees, which does show that the system is cooling.
my big question is does this cycle sound normal? I am testing this in the evening with hopes that it will make figuring out this issue easier so I have normal running ac for the hot days ahead. I still have about 4-6 oz in the can of refrigerant, but I am unsure of the capacity and I don't want to risk overfilling the system.
