bdufpv
- February 15, 2014
- Phoenix Arizona
- 2002 Ford Explorer
I have a 2002 eddie baur explorer with the 4.0 sohc engine and rear AC.
the compressor was not kicking on so i added freon. I only had the low pressure gauge at the time. i charged it to 45 psi and the compressor kicked on and the low side pressure immediately began to drop and the compressor turned off at 17 psi (the ac low pressure switch doing its job). once it kicks off the pressure builds back up to 45 psi, the compressor kicks on and the pressure immediately begins to drop again. this process will continue until i turn the ac off.
i have since gotten the high and low side gauges.
with the engine off the
low side is at 50psi
high side is at 50 psi
with the engine at 1500 rpms, the ac on max cold and max fan and the ambient temperature 75 degrees and a fan blowing on the engine compartment…
the low side starts at 50psi the compressor kicks on and drops to 17psi and kicks off- the same scenario as described above
the high side goes up to 80 psi when the compressor kicks on and drops to 60psi when the compressor kicks off.
the low pressure on the high pressure side sounds like the compressor is wearing out. is this what is happening?
i am not sure why the low pressure side goes up and down. is it related to the compressor? is there air in the system? i put some uv dye in the system i haven't found the leak yet.
i will have to do research on what causes the compressor to wear out and what other parts need to be replaced if that is my problem. i am hoping you guys can tell me before i spend a lot of time researching the wrong topics.
thanks
brian
thanks
brian
