Done!
WOW!!!WHAT A DIFFERENCE!!! I finally finished! My original problem was two-fold: I had to drop the fuel tank because it was leaking really bad, and I also had to replace the vacuum modulator because my '94 Exp was drinking about a quart of ATF almost every week.
So, following the threads I found here helped me tremendously with both tasks. I found better info and tips here than with my friggin' Chilton's.
Anyhow, after removing the modulator, here's what I did:
- Stuck a hose on the end of the vacuum line
- Started the truck
- Got the rpms up to 1500-2000
- Stuck the other end of the hose in a 16 oz bottle of tap water
- Let the vacuum suck up the water while maintaining the rpms
A bunch of black gunk came out of the tailpipe. I then reinstalled the new vacuum modulator($17.99 at AutoZone) with the pin being held by a dab of vaseline(just like I read in one of these threads), and put the carpet, center console and seats back.
I then replaced the plugs, topped off the ATF, and away I went.
After a test drive, I noticed the gears change a lot smoother, and my gas gauge works now! I was so thrilled, I washed and waxed her!
Thanks for all your help...this site rocks!
:exp:
