Add-a-leaf for 95+ Sports | Ford Explorer Forums
JBHexplorer
Gainesville, FL
'96 Sport
Ok, I just spent a couple of hours going through old post trying to learn as much as I can about the possible options for lifting 95+ explorers. But from what I read, it seems that no one makes an add-a-leaf for the 3" wide monoleaf rear spring on 95+ sports. Is this still the case or are the shackle and OME springs the only available options?
Leaves
Summit lists an add-a-leaf for an F truck that is 3" wide and about $50 bucks. Might work.
Rick
i have a 95 sport . that has a mono leaf ,,, i took to a spring works ..place and they . made one that would fit ..it cost about a $130...it gave me a 3 inch lift ,,,
95Sportb,
How did you remedy the front end? I have yet to see anyone twist their torsion bars 3". Really just wondering because I have a '95 too.
you don't need 3" in the front. The rear sags so much on those trucks that 3" in the rear and 1.75" on the front (T-bar twist) pretty much does it.
I only have a 1/2" sag in the rear......would these 3" leafs be bad for me?
