Advice for an Air conditioner problem | Ford Explorer Forums
Mark2001ExpSpor
Ridgeland, MS
01 Explorer Sport
I have a 2001 Explorer Sport and while in operation, the fan for the AC just stopped. The compressor the the AC still kicks off and on when you turn the AC on, but there is no air flow. The knob for air control does nothing, and the fuses all seem to be good. Any suggestions on what to look for before taking it in for a repair. The fan does not run with the heater or defroster turned on either.
Thanks
All I can say is check all your fuses and if not that, your blower might just be out or something is wrong with the wiring. Could have an open circuit somewhere. You can use a test light to check your fuses, but a DMM (digital multimeter) is better. Good luck. Check both sides of fuses
-Drew
