Aerostar 4.0 heads. | Ford Explorer Forums
Aerostar 4.0 heads.
sploder92
boonies, indiana
'92 XLT X, 93 ranger
Has anyone used 4.0 heads off an Aerostar minivan? As long as the casting numbers are the same they should work, right. :confused:
Where, EXACTLY is the casting number? Is all the casting numers/letters together? The only thing I can find on my heads is the number 91 between two valve springs. :confused:
Wow
Wow, :D thank you very much, that is the kind of information I have been looking for :thumbsup: .
I love having every bit of information, even if someone else would think it's useless knowledge, way cool :thumbsup:
Now I know exactly what to look for in a donor truck, for heads.
:thumbsup: Glad it helped. Even though the info is intended for Rangers, our Explorers are similiar mechanically, as are the Aerostars. Good luck with matching your heads.
we'll see
I ordered a used, non cracked head off ebay for $33.00 +shp(18.00)
I will see if it works, it should, will keep the peeps posted, I could have gotten two if I'd called a day earlier.
