Aiming headlights | Ford Explorer Forums
Aiming headlights
TravisC
My bro, JoshC in Iraq
Hurricane, WV
'92 Sport
I was wondering if there was any other way of aiming my headlights other than going to the dealership. I have a '92 Sport that I just purchased and it's got a lift on it. Well when I'm driving at night I can't see a whole lot of what's right in front of me because my headlights are too high. I know the dealership will do it but I really don't want to pay for anything that I can do myself. Can anyone help me out here?
Thanks
I'm pretty sure there is some tool you can use that adjusts the headlights. I just can't think of it right now.
Its probably not factory approved, but I have adjusted my own headlights by parking about 25ft or so from a solid wall so you can see the pattern and then adjusting pattern up/down left /right as appropriate. This was several years ago on a Toyota PU, I believe I used information in Haynes manual to determine distance from wall and location of beam etc.
I have also seen a reasonably priced tool for adjusting headlights from this company http://www.hopkinsmfg.com , but I don't see it on their website, just the more expensive pro versions. I don't know if the one I saw would work for composite headlights (like on the Explorer) or if it was for the older sealed beam headlights only.
By the way if your Explorer's headlight adjustment is anything like my '97s and my Wife's '93 Mercury Sable, the special tool is called a 5/32" socket on a nut-driver handle. Most auto parts stores also carry what they call a "Ford headlight adjusting tool". It is a socket of the correct size on a "T" handle about 3" long. There is nothing difficult (or wrong) about adjusting your headlights yourself. Your manual might even have the proper height, but if not both a Chiltons and a Haynes manual will. The procedure involves parking a certain distance from a wall and turn your headlight adjuster up or down until your headlights hit the wall at the proper height. I have found that parking on the street in front of my house and adjusting them up or down so they shine where I want them to works just as well for me. I put my headlights right where I want them.
Thanks for the replies, I'm going to give it a try today. I don't see any reason for paying someone else to do it when I know it's not going to be that hard. Thanks again.
travisc
have you considered a pair of fog lights?
you can spend a little or a lot for them.
btw we now have 3 members here in the hurricane area!
we'll have to hook up with joshc for a get together.
it looks like we have all 3 generations of explorers.
peter
xlt-sport,
JoshC is my brother, he's the one that got me into all fo this. I used to have an Explorer a few years ago but couldn't afford the gas and now I've got one again. We will have to look each other up and go get a little muddy. But yeah I have considered foglights but right now the funds aren't there and the simple fact that I'm blinding everyone that passes me. So I was just wanting to fix that part of it.
Thanks
