Air bag light is on? | Ford Explorer Forums
gungadin
2002 Explorer - my air bag light comes on when I start the car, flashes 3x with a short pause (1 second?) then does another 3x, then a longer (3 second?) pause, and it repeats with 3x, 3x - long pause, 3x, 3x - a total of maybe 6 cycles.... then it just stays on.
Supposedly this is a diagnostic code, but I have no idea what it means other than something is wrong with my air bags...
Can anyone help diagnose this for me before I throw money to the dealer to tell me something dumb like "it's a blown fuse"...
Thanks!
Code 33, I get #36, Al gets #37, someone will know what the #33 is, just wait. Welcome to the site,
Actually, I *just* found this online (sorry, no 36 or 37!) ... of course, I have no idea what Pin 7 is, or even if this is the right chart for my vehicle - anybody??
Air Bag Fault Code Table
AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
| -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
| 12 Low Battery Voltage
| 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
| 21 Safing Sensor - Not Mounted on Vehicle Properly
| 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
| 23 Safing Sensor Input Feed/Return Circuit Open
| 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
| 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
| 33 Pin 7 Not Grounded at Diagnostic Monitor
| 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
| 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
| 41 Crash Sensor Circuit - High Resistance or Open
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
| 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
| 52 Backup Power Supply - Voltage Boost Fault
| 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
airbag light on
Well the airbag light on my 01 flashes 3x then 7x for a number of times then stays on continusly. Any one know what error code this is?
Airbag Light On
Yes. I have already tried cleaning the yellow connector, but the airbag light still flashes 3x 7x. Does anybody know what this code is? Thanks for the replies. This is an awesome forum.
