Air conditioner/Defroster problem??? | Ford Explorer Forums
jakejeff
ontario
1994 xl
When I switch my controls to either air conditioner or defrost my engine immediatly turns off?? Any idea what could be wrong?
anybody? please?
I have no idea why it is doing it, but in either position you are turning on the a/c compressor.
I'm not sure if this is even possible, but maybe the a/c compressor is locked up. You can check this by taking the wires off the a/c compressor. Now when you switch the knob to a/c or defrost the a/c clutch won't lock. If it still does it, you know it isn't the compressor.. You may have to just work your way backwards to find where the problem is.
~Mark
thanks I will try it
It could also be the IAC. Do you have any rough idle when a/c is off?
no the idle is o.k w/o a/c
It's an odds on bet your compressor is locked up.
Chris
Good show chap!!! That's my bet too.
