bindery1
- May 1, 2004
- Huntersville, NC
- '96 Eddie Bauer
My '96 EB has an electronic AC/heater. When it is set on "max ac" it will freeze you. If it is turned up one degree (65 or higher) it goes to full heat which will cook you. (There is no in between.) Also, it sometimes will not do anything at all but this happens only when it is first started. I have discovered that when this "refusal to start" happens, slamming the pasenger door will sometimes get it to come on. Other than that, the system works just fine.
I could realy use some advice. Thank you.
