steelman83
- April 23, 2014
- portsmouth va
- 2003 explorer xlt 4.0 4wd
My airbag light was on and failed for inspection on my 2003 Ex xlt 4x4 V6. After some research. I determined it was the white connectors under the seat. I used electrical contact cleaner spray to clean them out. Disconnect the battery first. After spraying them out thoroughly let it dry over night (you may not need to let it sit that long but I did) before you reconnect anything. Reconnect them and the battery the next day and presto, the light is gone! Worked for me. Should work for a code 33 as well I believe. Good luck!
