BuffaloXplorer
The X had to go!
- April 5, 2004
- Buffalo, New York
- 2006 Impala SS
I've been getting code "44" for my SRS/Airbag system and am due for an inspection soon. From what i've read here, code 44 is related to the Front-Right Crash Sensor - not mounted properly or high resistance to ground(?). Some have said it may just be corrosion between the sensor & mounting point. I think i know where it is and from what i see it's not easy to get to. Also, i know that the system should be disabled for a bit before i tackle the job (unhook battery and/or remove fuse). Is there a way to test the sensor to determine where the fault lies? How much is this sensor and where can i get one? Thanks for the help!
