foxak
- February 12, 2005
- Alaska
- 1998 XLT V6 SOHC
I have a 98 XLT V6 4.0L SOHC. It is normally parked in a heated garage. Back in Dec. it sat outside overnight with temperatures at -10 degrees. When I went to start it, it had a hard time and the idle would rev up and down. Held my foot on the accelerator to help it out. After warming up for 10 min. or so, the CEL came on and it ran just fine. Took it to my mechanic. When I picked it up he said it was a "random misfire". Couldn't fine anything. A week or so later after driving for 5 min in -5 temp (and it sat INSIDE the garage), the CEL came on. Took it back in, codes PO174 and PO171 show and this time he cleaned the MAF sensor. (Guess certain model years are prone to problems with MAF sensor.) CEL comes back on a week later, now this time he replace the MAF sensor. When the explorer sat outside for 8 hours in below zero temp, again had problem with the engine idle running up and down when I started it. The check engine light comes on. After the engine is warmed up, it runs fine. It is just with these frigid cold starts.
I haven't taken it back in .........
Any ideas? Thanks
Any ideas? Thanks
