schadler
- August 14, 2002
- Allentown, PA
- Explorer '97 XLT V8 AWD
Just a warning that anyone using Albany brake pads (Autozone) should check that they don't sell you mismatched rear pads. I tried replacing my rears on a 97 XLT to find that I could not because the notches on the pads didn't line up. When I returned them, ALL of their inventory had mismatched pads, and I had to get the Raybestos.
To check, put the pads facing each other (the inside pad has a "claw" like part, the outside has 2 clips), as if they were installed on the caliper. The bottoms of the pads should both have a U-shaped notch, and the top should have a half-U...this allows the bottoms to sit squarely on the slide, and the tops rock into place. If you have mismatched pads, the "U's" won't line up (they'll be on opposite sides), and you won't be able to rock them onto the slides properly.
