Alignment after coil spacers | Ford Explorer Forums
nak4af
Bellevue, Nebraska
1993 Explorer Sport
:frustrate O.K.! After installing my F150 spacers I go and talk with the guy at the alignment shop and he tells me that I'll need bushings to correct the angle and such. The total for the alignment comes to $139 plus the cost of the bushings. The price is the same at other shops as well. WTF!! Heck for $150+ I could add a bit more and get the JD kit. I thought this was a "cheap" lift!
My question is...Is there a better/easier way to correct the camber myself? If not I'll just take the spacers out and say heck with it. What to do?
Please help guys! I'm kinda stuck here.
Mine aligned fine, the adjustment was maxed out pretty much though.
To do the job correctly, you will need the adjusters. However, this is a one time purchase.
Good luck....
toad
You mean after adding your F150 spacers, you only needed to adjust? No bushing purchace necassary? That sounds good too me!
What should I exect to pay for the alignment?
Thanks for the replies! :thumbsup:
aldive
Where do you get the adjusters from?
Any quality alignment shop should have them in stock.
Good luck.....
COOL!! Thanks alot. Wish me luck as I head off to the alignment shop...TBC!!
how did things go with the alignment shop? i am thinking of doing the same "cheap" lift.
