Alignment after lift? | Ford Explorer Forums
slapthefunkyfou
Farmington, Utah
'91 XL
How long should I wait before I get an alignment done? I assume that the new springs will settle a little bit, and so if you get the alignment done too soon, will you have to do it again once the springs settle in? Does it even make that much of a difference if I wait or not?
depends on how fast you like to go through tires, usually you should do it right after the lift but a week or two shouldnt make a difference in the treadware if its not way outta alignment
