All bolt sizes regarding Intake..... | Ford Explorer Forums
Limited Ex
Elite Lurker
Greensboro, North Carolina
94 Limited
I just got done today replacing all intake gaskets along with both valve cover gaskets, EGR valve gasket, and IAC valve gasket. In order to help me remember what socket sizes went with what bolts, I started compiling a list of all the bolts, and their sizes, that I came accross in this process. I used this as a reference when I was putting everything back together, so I thought I would put it here in the chance it may help someone else who has as bad a memory as mine :p
KKM bracket bolts = 11mm
MAS sensor Torx bolts = T20H
Alternator-
+Bolts = 1/2
+Ground Nut = 10mm
AC Compressor bolts = 10mm
Belt Tensioner = 3/8
Ground Strap/Vac line holder bolt = 13mm
Throttle Cable-
+Dust cover = 5/16
+Bracket = 10mm
Bracket bolt* = 10mm
Vac Line holder bolts* = 5/16
EGR valve bolts = 10mm
IAC valve bolts = 10mm
Ignition Coil bolts-
+Upper two = 1/2
+Lower one = 17mm
Upper Intake Manifold nuts = 1/2
Fuel Line fittings (at fuel rail)-
+Front = 11/16
+Rear = 3/4
Fuel Rail Torx studs = 5mm
Valve Cover bolts = 10mm
Lower Intake manifold bolts = 10mm
Water Temp sender = 11/16
Engine Coolant temp sender = forgot to write down :D
Thermostat housing bolts = 10mm
I am pretty sure I got them all. The ones with the *s hold things that I do not know the technical term for. I would have to post a pic if anyone wanted to know what I was talking about. I did not go and buy the proper sockets for the torx studs on the fuel rail, but I did find that a 5mm socket will get the job done also :D
Any comments or questions are welcome!
