Hello, I have a 2001 Explorer. I got fiber glass stock running boards from a local junk yard and they did not have the hardware to install these.
The brackets are on the running boards! My question is:
- what size bolts with nuts/washers do I use to install these? (most important)
- there is another part with 1 screw hole, what size screw do I use? And why does it look like they won't match up? see pic below
Here's pics of what I'm talkling about:
This is where I would mount on the car underside:
This is from the under neath the car with the 2 bolts from previos pic and the screw on top:
Here's the bracket on the running boards. The 2 holes which I circled are where i think I install the boards, the circle on top is for the screw, and the question mark(?) is don't know:
Any help would be much appreciated!!!!!!!!!
Thank you, Jerry
Thank you, Jerry
