inkjunkie
- January 20, 2013
- West of Spokane Washington
- 99 Explorer
ABS light. No broken wires. Sensor replaced, have not checked to see if it is snotted up but will tomorrow. Driving with cruise set....starts to surge ever so slightly then ABS light will come on. If the ABS light is not on when coming to a stop pedal will pulse, ABS pump is groaning and ABS light will come on. Thought it might have been my repair I had to do on the wires going to the rear sensor but with truck up on jack stands and idling can wiggle the harness...and light stays off. C1230 was the only code last I looked. Truck has 300+k on it. Other problem....Come to a stop, warmed up. Idle will hang up over 1k rpm for a second or two and then drop to normal. But when the idle drops the oil pressure gauge will fall to the oil pressure pin ( just like when shutting it off) but soon as idle stabilizes oil pressure gauge bounces back to normal. Have replace the OP sender a while back...long before this problem started.
