1998Exp
- December 5, 2010
- Seattle WA
- 98 Limited V8 AWD
Troubleshooting the CC in my 1998 Limited. I have the 1998 EVTM, but the schematic does not match reality. Because it's a late 1998, there is a chance that a 1999 schematic will be closer. If you have one, please post, thanks!
Details: CC worked intermittently, then died.
Diagnostics don't work, but I believe that they don't apply to the Limited with its additional functions on the steering wheel - they never worked, even when the CC was fine.
I checked the clock spring and it's fine. The switches on the left side of the steering wheel that control the CC all work and produce the right resistance, except for "resume," which appears to have a burned resistor. There is obviously more to it, because the CC won't even engage. The servo itself appears to be fine (I substituted another one, and no change). The clock spring shows continuity on all circuits and to the servo. Not so sure about connections inside the steering wheel between the clock spring and the push button assembly, but that's where the schematic does not match reality.
