EBfan
- June 1, 2015
- Vermont
- '05 Explorer EB 4.6 V8
Ok so i'm getting ready to order some parts to cure out some or hopefully all of the rumble strip feeling in my 2005 4.6L V8 Eddie Bauer ex - Just hoping you guys can just take a look at my list and see if there is anything missing that may cause that type of vibration.
Please note although there may be a little chance of the wheel needing balancing (or all of them) i bought the vehicle two months ago and this has been there since the first week - The tires are new and were balanced and aligned at the same time although not in my hands at the time. Adding onto this it's making a knocking feeling like something is loose underneath more so when it's warm than cold outside. This i can feel through the pedal more than the steering wheel and the steering is tight and responsive throughout.
Anyways i currently have in my cart
SKF wheel hubs for the front - There is a wheel bearing whine and starts to grumble over 60 more on the left corners than the right but i'm figuring on changing them both out
Front right hand UCA & LCA - The rubber bushing on the lower mount has visibly started to crack and degrade - The upper is getting rusty so i figured i'd change them out at the same time - It might even be worth doing the same on the other side ??
Sway bar links - Same as above bushings are worn
Front rotors and pads - Got that warped rotor feeling under breaking
Hopefully that should put a stop to the rumbles and groans at least getting me through the winter when it gets here.. It's my work and family car so safe and reliable is key for me - Anything i might have missed in that little lot ?
Thanks in advance
Thanks in advance
