PEAR0119
- January 29, 2010
- Ottawa, Ontario
- 2006 Explorer XLT 4.0 4x4
Well, after replacing the tensioner and idler pulleys I finally got rid of a lot of bearing noise from the front of the engine. But now with them being quiet I can hear the alternator bearing grinding and squealing.
So I took the belt off and turned the alt. by hand, and realized that it is in fact the alt. that is causing my noises. if I turn it clock wise I can hear a grinding noise in certain spots in the bearing, if I turn it counterclockwise the rear bearing squeaks quite loud.
Has any ever replaced the bearings in their alt.? If so was it very difficult? And are there any additional parts that I would need besides the bearing? I have checked the voltage and the alt. is still working well so there won't be any need to replace anything else.
