KC90
- November 28, 2009
- Kootenay's
- '99 Explorer XLT
An issue I have with my alternator led me to curiosity of its harness. The harness has 3 connections - the 2 on the outside have wires, the middle does not.
In my Haynes repair book it says that the harness ignition off should produce 12V+ on 1 connector. Ignition on( engine not running) 1 connector should produce 12V+ and 1 produces 1V.
I tested this on my eX - Ignition off, 1 connector has 12.38V. Ignition on( engine off), 1 conector has 12.38 and the other 1 reads 12.03V.
The one reading 12.03 is leading me to believe its linked to my voltage problem. Just in case I'll ask , what voltage should those connectors be?
My main problem is my Alternator produces around 13V at idle (I've seen it hit high 12Vs a few times now), and in between 13.8-14.1V reved to about 1500RPM (Not once seen 14.4V its supposed to be, even revved to 2000+RPM).
Alternator is a Mechman 270a. Even my stock Alternator does this.
ALSO, when I first got my eX, the stock alternator produced 14.4V. It decreased to 14V after I put my system in. All voltage readings I took were with the system COMEPLETELY off, headunit and all.
Thanks and any info is appreciated.
