explorer93xlt
- January 27, 2000
- parlin, NY
- 93xlt 4x4
Big Problem
ok i was coming out of work and i noticed my amp was still on DAM well i luckely put a fuse switch under the hood so i fliped it and it went off, the problem is that when ever i turn my radio on the amp come on first makes like a pop noise(never noticed this before) then it seems ok, but i can't turn it off once its on it stays on.. whats the problem?? so what i did was i checked all the wires and they are all perfect, now when i turn the radio on and then the amp nothing happens?? did the Fin thing blow all the fuses are good?? is their anything I should check or should i go take out the old warrenty card, the amp is a Power Acustik 600w 4 channel Please help this is a link if you not sure on the amp http://home.att.net/~riccardis/Explorer1.html its only about 4 months old DAM
