AMP PLACEMENT HELP!! | Ford Explorer Forums
Pimpin Yoda
Oklahoma City, Ok
Explorer '96 XLT 4x4
Hey i did a search and came up with no pics of people putting it in the rear panel. I want to see some pics b/c i already did it and need something to cover up the hole now. Please dont just say "Do a search!" I already did and came up with nothing. Thanx
I know someone out there has to have pics...Please post! You all can do i know!!!:bounce: :bounce: :bounce:
Behind you rear seat there is a panel in which moves as you put your seats up and down. Mount your amp there on the paasenger side as low as you can go. then you can pull the RCA cables up threw there and your power cable. NOTE: Run your RCA cables on the other sideof your Power Cable. What type of AMP are you going to get?
Aaron
Check out my post on the Registary, I have my sterio listed for the most part. Except for the AMP ( Fostgate ) and the Head Unit ( Pioneer ) Ok talk to you later
thats where my amp is mounted..........right underneath the rear passenger seat flap. mounte4d with 4 brackets. pretty simple. very accesible. and not noticible from the outside. it's basically hidden which is good. depending on what size amp you have will depend if you can put it in the rear panel. BUT if you already did mount it in the rear panel-this is how "samtheham" covered up his new hole Dead Link Removed
