RyanExplr01
- January 3, 2005
- Northeastern PA
- 2001 XLT
What amp should I buy to power my 2 12" CVR's ? Also would I be better with a 2 channel or mono ?
davesexplorer said:the comp vr's are dvc right? what ohms are they dual 4 or dual 2?
Wagonized said:if you have a 2 channel amp you want to bridge it to a mono signal...you dont want your subs playing in stereo.
this can be a little more complicated than just wiring all the positives to one side and all the negatives to another.
what impedence (ohms) were the subs that you bought and if they're svc or dvc?
btw that soundstream amp you have a link to is fairly decent. price looks a bit high though to me. If thats your price range id go pick up a JBL 1200.1 off of ebay and keep your gains down for this setup. That way you have more than enough power to upgrade in the future
Wagonized said:two dvc 4 ohm subs with coils wired in series and subs in parallel will give you a 2 ohm mono load.
look for an amp that puts out atleast 600 wattsX1@2ohm and you're set... JBL600.1 will do the trick or you can just go for the 1200.1
