Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
So I had my fuel pump replaced a few weeks back under warranty which was definitely the problem. I had for a week and it was running just fine. Then after I had been driving it for a couple hours straight, I went home shut it off for a couple of hours before I tried to start it again. To my surprise it was hard starting again. I took it back to the shop to have them check the pump again and the pump checks out fine. They delved a little further into my car and they came up with a recall/TSB for my Ex. Apparently what happens after my engine bay has been heat soaked and the vehicle has been turned off us the heat makes the battery voltage drop a bit and this deactivated my fuel injectors. It takes a couple of times cranking it to get it started again and once started the idle kind of wanders a bit as well as giving the feeling that it’s running a little rough. They printed out the TSB for me so I can take it to ford. The earliest appointment I could get was this upcoming Monday the 17th. According to the shop I had it at, they said Ford should just have to re-flash my pcm and should solve my issue.
The thing that I’m a little thrown by is that last year I had my computer re-flashed because I thought I might be missing updates for my transmission. It would do a funny shift even after a new transmission was installed.The Ford dealer said I was missing 1 update was all. So I thought everything was up to date from the last time I took it in but this tsb pretty much describes to a T what my car is doing.
I did install new injectors and a new fuel rail pressure sensor before I came to the conclusion that it was the fuel pump. I wonder if those new components are part of what needs to be reset when they do a re-flash. I figured they were just plug and play... perhaps not.
Anyway, I was wondering if anyone had ever heard of this issue/recall before?
