Another Gas Milage Thread | Ford Explorer Forums
watisgood
LoNg IsLaNd
1997 ford explorer sport
Hey Guys,
I've done the following to try to improve my gas mileage:
Spark plugs
Wires
Seafoam
Fuel injector cleaner
Fuel filter
Radiator flush and Thermostat
Intake
change my driving habits (never rev past 2,500)
I do the most on a tank 250 miles this come out to about 15 miles per gallon. There has to be something I can do to improve mileage? I don't even drive past 65 any more.
First, might i suggest checking:
http://www.explorerforum.com/forums/showthread.php?t=44372&highlight=quest
Also check your tire pressure.
You said you have done and intake. Did you get an oiled filter like a K&N? If so you might want to clean your MAF with some electric parts cleaner (the kind that evaporates). Sometimes they can be over-oiled and start fouliing the MAF giving your comp. bad readings.
In a mix of 50% city, 50% highway, my 4.0 OHV fluctuates between 15-18 for a tank with super light throttle. You're not off. And I don't drive over 65 either, that's just the way it is, and how she runs. :)
whats your warm idle rpm's at? you could adjust your tps and clean your maf for free. spend a little money and get a highflow air filter and switch to full synthetic oils n' lubes.
