bvenvert
- September 14, 2005
- Springfield, Illinois
- 91 Ranger XLT
Hey guys
I am looking for some suggestions on fixing and idle probelm I have. I own a 91 Ranger with 4.0L that has issues with idle once it reaches normal operating temperature. When I first start the vehicle, everything works great, the truck idles fine and generally run pretty good for a now 18 year old truck.
Once it reaches normal operating temperature I run into a rough idle problem along with an erractic oil pressure gauge. If I pull up to a stoplight, the oil pressure will drop down below the normal level and start to fluctuate radically along with the low/rough idle. Once I hit the gas the oil pressure jumps right back to the normal level and the truck runs fine again. It acts like the idle gets too low to properly feed the system and therefore the oil pressure drops off.
I have read a lot of information through this forum and I am considering changing my IAC and cleaning my MAF, but I thought it might make sense to document my problem for the group, since I don't want to just throw parts at it. Not to mention that it runs fine at startup until it gets warm, which would make me think it may be a sensor that is associated with the operating temperture of the vehicle. I have read a bunch about vacuum leaks, but I would think it would occur at startup, as well as normal operating temperture if it was a vacuum leak.
Any help would be appreciated.
