IAR
- May 24, 2009
- Kansas City, KS
- '06 EB V6
So here goes for anyone who is just stumbling their way into something similar,
Sept 2014 - after a DIY tune-up (plugs, wires, oil, filters) to resolve a suddenly slight rough acceleration (approx. 40-50MPH only) the truck was running the best it ever had, save for not correcting the slight rough acceleration! Anyhow after reading through many of these threads, ordered a new EGR to hopefully save the day.
Meanwhile I was cruising the freeway in the early September sun with the moonroof open enjoying the ride and then bam! Billowing white smoke flying from under the hood and engine lights and flashing red CELs - like an airplane ****pit under duress. I'm at the top of the skyway at highway speed so nowhere to safely pull over so I drop into neutral to control steering and coast 2 miles down the other side of the bridge and there's no exit in sight... perfect! When I rolled to a stop I shut it off, sat for 5 minutes and popped the hood, coolant everywhere! About 20,000 miles previously I had replaced the factory radiator, as we all know it has its issues, so I looked it over good expecting the coolant to be pissing out, no dice. It was hard to see for all the steam so I let it sit another 10 minutes, added the small bottle of coolant I had directly to the rad and started it up to slow idle off the freeway to the gas station at the closest exit. (<1 mile)
Local garage fixed the thermostat housing which had cracked, and the thermostat
and got it back together 5 hrs. later.
The way home the truck ran real rough. Gone was the great tune-up feel from that afternoon, but at least I was able to get home.
Finally had to bite the bullet and take to Ford dealership after no heat at idle (but otherwise cabin heat was great), and the news was not good - head gasket repair!
$1500 later not including the $300 emergency thermostat housing repair, the truck was running but the no heat at anything below 2K RPM was still there.
Also there was still a small misfire in No.1 cylinder, enough to trigger the CEL here and there. Tech said maybe 1 miss in every 100K or so. Not what I wanted to hear after shelling out fifteen hundo, but hey it's just $$ right? I live in the snow belt so with a newborn so no heat wasn't going to fly. Couldn't pre-heat the car in the driveway, no defrost - at least the heated seats would work.
Back to Ford, they said the emergency thermostat housing fix had been done with silicone and then Bars Leak added which after 6 more cooling system flushings still was pushing out residue which they believe was blocking heat at low RPMs. Heater line was hot hot coming out but ice cold heading into the cabin.
Heater core fix is $800, used 62,000 mile motor is $4200 installed at Ford.
I have done neither, the truck is a 2006 4.0L EB with 120,000 miles, not sure of that ROI. Sucked it up and drove fast to hit 2,000 RPM for heat - hard to do in the city, and bought a Cadillac for the wife and baby.
Truck is leaking coolant again at a rate of 1/2 jug per week. Rad is still good but the thermostat housing made of fine Chinese plastic is a leaky sieve. Nice to see they only sell more plastic replacements, I know there is a metal solution but it's in Tennessee and I'm not - so tomorrow I'll fix with another piece of plastic....
I still like my Ford but the cooling system is really, really, really more than a joke.
