Another SOHC timing chain overhaul | Page 2 | Ford Explorer Forums
Not sure.... I still have mine.
Get the instructions from 2000StreetRod up there.
When I did mine, I put the 4x4 Balance shaft in it, but had it timed wrong, so it vibrated. Just now got around to fixing it with the motor still in the Explorer (Doing rack at the same time, had to drop the front axle too)
If you are just replacing the timing cassettes, you shouldn't need to time the balance shaft however.
could you tell me how to change the timing on the balance shaft ?
